Prolem to connect unit to online - Страница 2
Страница 2 из 4 ПерваяПервая 1234 ПоследняяПоследняя
Показано с 21 по 40 из 70
  1. #21
    italy
    A question I have About Google icon in the monitor.
    Even if Google Earth is working well I do not see tha icon of "Google 3G" in the bottom right corner of MMI.
    Is it possibile to insert it?
  2. #22
    hi Spinmar
    yes - I have gogle earth and other working services like fuel prices, weather etc
  3. #23
    United Kingdom
    spinmar could you share the scripts, please?
    I'm trying to use sergeynik script but I cannot change the resolv.conf if I use the command "echo nameserver xxx.xxx.xxx.xxx > /mnt/efs-system/etc/resolv.conf" from run.sh.
    Do I need to create another script and upload it to /mnt/efs-system/scripts and then using sergeynik run.sh just touch that file to run it?
    Luca
  4. #24
    italy
    @Paszczak: the services you are writing ( fuel prices, weather, etc...), are ok. Google earth and tmc online are working well.
    I'm asking how to insert the Google icon in the bottom right corner of MMI display, where now I have the time.
    @jjlucas76: you can download the file http://www.datafilehost.com/d/63f6b577
    Maybe the trick is the value of channel 69.
    Yesterday I compared my value with the value of a friend of mine who has unit 670 and then he has the Google icon.
    Ma value of channel 69: 32783 (bit 0, 1, 2, 3, 15 setted);
    My friend: 32776 (bit 3, 15 setted);
    So I have bit 0, 1, 2 setted while my friend not.
    How is the meaning of these bits?
    Do I have to deselect them?
    Thanks
    Последний раз редактировалось spinmar; 20.03.2014 в 17:22.
  5. #25
    United Kingdom
    Many Thanks I'll try to get Google online first and then report back about the google icon in the corner.
    My head has 767 installed.
  6. #26
    Yesterday I compared my value with the value of a friend of mine who has unit 760 and then he has the Google icon.
    Thanks
    I have HW 670 (build in sim card) - my channel 69 has value 32783 - but before I had there value 15 then no traffic online menu.but before even value was 15 I had google icon also so I dont think so its related with this icon
    what do u mean bit 0,1,2,3, 15 setted? in adaption I am able to set new value only do u mean long coding?
    Spinmar - if u want I can scan my settings for you for compare - just let me know what we should to compare.
    I am intresting in compare with yours cause my traffc online still doesnt works
    Последний раз редактировалось paszczak; 20.03.2014 в 17:12.
  7. #27
    italy
    This is a bad news
    It means that the google icon is not related to the value of channel 69.
    Probably only Sergey can help us
  8. #28
    This is a bad news
  9. #29
    italy
    They are related to the value of the channel.
    Only Sergey knows exactly the meaning of each bit.
  10. #30
    can you tell me yours bit setted? can you show me your screenshots? I dont know where shall I looking for - as I wrote in adaptation I am able to set value only
  11. #31
    italy
    Maybe I'm not clear enough.
    In adaptation 10 there are 255 channels and for each channel you can set a value.
    You cannot set each bit but you can set only a value which you can image as composed by different bit.
    So as sergey wrote, to set bit 15 means +32768.
    Only few persons knows the meaning of each bit and Sergey is one of these.
    I'd like to add Google icon to bottom right corner and I don't know how to do it.
  12. #32
    ok clear but bu what mean in this case that u have setted bit 0,1,2,3 and 15? and your friend just bit 3?
    so in case o your friend if set bit 3 in channel 69 means his value is 32776 - but why not 3+32768 so 32771?
    how can you set in same time bit 0,1,2,3 and 15? sorry I really dont understand - but I really want to compare my settings with your or your friend for get traffic online finaly - hope you will help me
  13. #33
    italy
    I have bit 0,1,2,3,15 setted. This means value 32783.
    My friend: bit 3, 15 setted. This means value 32776
    bit 3 means +8
    bi 15 means +32768
    It means set my value: 32783
  14. #34
    bit 3 means +8
    bi 15 means +32768
    so whats possible value range for channel 69? 15 and then 32768 up to 32783? what was your original factory value there? 15?
    I am asking about range cause I want to set diffrent values for solve my issue with traffic online
    Hi Sergey
    do u think my problem with traffic online is related with wrong value in channel 69?
    Последний раз редактировалось paszczak; 20.03.2014 в 19:30.
  15. #35
    United Kingdom
    I have managed to get the head online. no google icon on the right bottom corner of the MMI, but everything else works as expected.
    Big thanks to Sergey and Spinmar for the knowledge and for sharing.
    @Spinmar have you managed to change the adapter speed to 100Mbit, not that it will make any difference in performance, as the bottleneck here is the 3G connection, but just curios if you did and how.
    I am using:
    -DLINK adapter DUB-E 100 ver B1 for USB -> LAN converter
    -Vonets VAR11N as WISP client
    -2 Ports USB adapter to duplicate the port of the AUDI USB Cable.
    I had tried also the Gembird NIC-U1 as USB -> LAN converter but i snot recognised by the head.
  16. #36
    italy
    Good!
    Unfortunately the Google icon is not related to 69 channel.
    Let's see if Sergey will tell us something.
  17. #37
    italy
    Problem solved
  18. #38
    United Kingdom
    what was it?
  19. #39
    United Kingdom
    Problem solved
    How did you get the Google icon to work?
  20. #40
    italy
    Hi jlukas the trick is in the submenu telephony of the hidden menu: you have to set Nad activation and nad operation mode.
    Try it and magically Google icon will be shown.
    Remember to restart mmi
