Audi MMI System Update Log - Can it be cleaned?
Показано с 1 по 17 из 17
    По умолчанию Audi MMI System Update Log - Can it be cleaned?
    Hi!
    жаль мой русский не очень хорошо ... Я надеюсь, вы не возражаете English
    I wanted to say that you are doing great stuff with the scripts for the MMI. I have a 3gp and it helped me removed a failed .fsc file!
    I wondered if a script can be created to clear/delete the system update log where it records past map and activation installations in the "setup+return" menu?
    Thanks so much, sorry for writing in English.
    XTed
    work script you find in this links
    http://turbo-quattro.com/showthread....-скрипт
    Great!
    So I need to look in "/HBpersistence/DataPST.db" and "/mnt/hmisql/DataPST.db" to find where the "log" items from the system updates are stored?
    I will take a look and see how I get on.
    I have a russian friend who helps
    SPB
    Цитата Сообщение от XTed Посмотреть сообщение
    Great!
    What is your final purpose ?
    The goal is to to "delete" the log entries that show in "engineering system update" screen.
    I have entries that show map and firmware installations for example.
    The menu that I mean is a MMI 3gp you press "car+back" - the menu where you install firmware or map updates. In this menu there is a "log" and I would like to remove all the entries.
    I hope this makes sense.
    Ok. In the Last Week I have Looked in the / HBpersistence / DataPST.db and / mnt / hmisql / DataPST.db for the Log Items but I can not Find Them. Also I Looked around the extracts That I pulled from the MMI Without luck using Recommended by the script sergeynik. Can someone help Locate where Log Files These are A or Method to delete Them? The ones I Mean That are as in the Attached picture. Thanks!
    Последний раз редактировалось XTed; 03.04.2014 в 13:40.
    Some news...
    I think I have found the "software update" log location:
    efs-persist\SWDL\Log\service
    efs-persist\SWDL\Log\user
    Can the contents of the directories just be deleted? Is it safe to delete these folders?
    remount "efs-persist" for r\w
    and move( delete) files
    That worked - logs are removed
    Thank you!
    Hi,
    you delete all file in user and service, or some?
    Have you script, or telnet?
    Thanks
    I deleted the complete folder using the script method from sergeynik using the commands:
    rm -f -r /mnt/efs-persist/SWDL/Log/service
    rm -f -r /mnt/efs-persist/SWDL/Log/user
    I have the same problem, wants to remove the keys from the navi audi q7 3g + because ive loaded vw key 00040405 in Audi Navi Q7 there though is the legal wants to remove vw key and install audi key 00040007
    helped me removed a failed .fsc file! and good .fsc file !
    The goal is to to "delete" the log entries that show in "engineering system update" screen. (clear/delete the system update log where it records past map and activation installations in the "setup+return" menu) (a lot of bad old logs whose now did not want me to have)
    Can you send me these two ready programs (ready script -program sd card - because I can not edit files and programs teeth do not spoil)
    I do not want to spoil the navi in my q7 3gp+ 2014 maps, sim-google, tmc-online, audiconnect, 767 DH
    Thanks in advance for your help
    Does anyone SCRIPT READY to clear/delete the system update log where it records past map and activation installations in the "setup+return" menu?
    XTed OR Any WHO, YOU CAN HELP - finished script, I'm trying to
    BUT NOT WORK (FREESCR - Sergeynik)
    MMI AUDI Q7 3GP+ SOFT 767
    Thanks so much,
    someone give up script worked
    please help me X.TED - YOU CLEAN LOG AND SCRIPT WORKED PLEAS HELP ME
    The commands that you need are
