Yeah, I mistake because I enter 6200000 instead 0x06200000 and think that 6200000 is in decimal base instead of hexadecimal how it should be 0x06200000, will try tomorrow again
You have done it correctly. the flashit command allways take it as hex . And the adress was correct for the efs-persist partition.
But it seems, that your Flash Memory occurs an error ... There is an automated recovery procedure build in. This recovery you can see in the print out also faults before you do it manually...
So it seems that the flash is damaged? Will try to heat up the flash to see what is happening.
hello
I would like to make connector JTAG for MMI 3G and 3G+ but the card edge connector is very little and I have not :
Good matérial for solder wire directly
My hands are not perfect for this !!
Is anyone could make this connector for me ?
Sure I will pay ...
There is product ready
http://www.ebay.com/itm/MMI3G-MMI3GP...sAAOSwmrlUtXNg
Here.
You can solder thin wires to the pads and try to use it.
The problem is you cant use the pads on the other side as they are not connected
I hope zerbino can make small correction and route the pins ...
I made one long time ago but it was pain in the a**
Hello
I have think to this solution but the pins are very small and it not possible to soldering to the bad side (I have the TTL near me and I confirm it impossible...)
Hi everione, another mmi3g ln my shop, can anyone tell me what is happening with this one? I cannot understand
Thanks
Последний раз редактировалось tehnosoftex; 28.08.2017 в 10:13.
Nevermind, it seems that is ok, I give a hard reset to the unit and system is starting ok.
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]
CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_09422A
(0ms)
*** emergency FPGA loaded!
*** Old-fashioned mark found on IFS @0x1c0000: .zero=0x30000011
starting image @1c0000 ...
Startup: PL_qnx_startup-sh7785_09332A, built 2009/08/11_11-10-29_UTC
RAM : 128 MB @0x08000000
RAM : 128 MB @0x40000000
RAM : 256 MB @0x50000000
FLASH: 128 MB @0x00000000
FPGA IRQ: Interrupt Controller ID:33 Ver:2.1.0 ILVL:7 Lines:255
ю
getdip
close
(0ms)
getdip
close
(0ms)
Entering CLI, type '?' or 'help' for help
=> boot 1c0000
starting image @801c0000 ...
X
getdip
close
(0ms)
возможно поднять через терминал или только программатор? черный экран
пока IPL жив программатор не нужен.
только никакие команды принимать не хочет, после boot 1c0000 просто ничего не вводится , или подымать именно в ipl
AUDI_CLI.txt audi.txt
аналогичная ситуация.
у меня после обновления легла MMI 9308
я скачал архив IFS9308, в режим CLI я попадаю.
Подскажите как мне восстановить голову? может есть скрипты которые принудительно прольют этот дамп в нее?
В CLI - после команды boot 1c0000 ничего не происходит.
В IPL - команды не доступны
Последний раз редактировалось dec123ua; 21.09.2017 в 18:36.
It's possible that the FPGA and IFS are not from same version.
If you know the exact version of IFS then you can load FPGA with zmodem and then boot.
how to load FPGA zmodem?
just send it over zmodem
transfer doesn't take place until the end of rns is turned off
