Неужели не у кого не было ничего похожего?
Hi everyone. Sorry, I cant speak russian. I get a mmi3g into my shop and try to diagnose it. It powers up but have no sound, no tuner signal and no media music play. I boot into normal mode and get this log but cant figure up what is happening. I attach my logs. Can anyone enlighten me.
Thank you
Sorin
tehnosoftex 99% broken HDD.
vsnic пропаяйте/замените память - проблема исчезнет. Если битый регистр например, то и возникнет ошибка
Последний раз редактировалось zerbino; 13.03.2017 в 13:28.
Всем привет.MMI 3g radio plus прошивка BBT_EU_K0020_D1
IPL: 3G_9304 / QNX 6.3.0 [PL_qnx_ipl-3g_9304_07284A, built 2007/07/12_09-15-16_UTC]
CPU: SH7785 (>= 5th cut, clk mode 16), 594MHz
RAM: 256 MB (probed, DBCONF=db0002)
FLASH: Spansion S29GL512N: 512 sectors x 256K
FPGA: PL_MMI3G_FPGA_9302_D1_08492A
(0ms)
*** emergency FPGA loaded!
Entering CLI, type '?' or 'help' for help
=> boot 1c0000
starting image @801c0000 ...
Startup: PL_qnx_startup-sh7785_08362A, built 2008/09/02_07-53-12_UTC
RAM : 256 MB @0x08000000
FLASH: 128 MB @0x00000000
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v88046840
Welcome to QNX 6.3.2 (RL_qnx_os_632_PSP3_08124A) MMI3G Audi EMERGENCY SETUP 9302 D1 09034A
starting pci driver
*** init FPGA registers ***
starting dev-ipc for IOC
initialize IPC Driver
starting network driver
starting i2c and devb-sercd-hbfpga driver - setup device /dev/cd0
starting devc-pty
starting flash driver
Path=0 - QSSL SERCD
target=0 lun=0 CD-ROM(5) - Philips CDM-M8 Rev: 45N
starting SDCard driver
Unable to access "/dev/io-net/en5" (2)
starting with no network driver
Emergency IFS is started. Emergency app tries to restore
the application.
49170 running /usr/sbin/io-display
49170 exited with status 0
53267 running /usr/apps/MMI3GEmergencyApp
Emergency shell started, fix your system and restart again
# Fpga header is not 0x4744482e (0xffffffff)!
App FPGA valid 0
Emergency FPGA valid 1
EmergencyApp-MMI3G: version 21.27.1642, date of build 14.01.2009
Number of displays: 1
Number of layers: 3
Graphics init was successfull: DisplaySize is 400x 240
OnOff: process IPC event 209 2
SWDL: startUpdate HW index 209, variant 9302
OnOff: phase Scan metainfo
We have to erase the FPGA, init the FPGA persistence and delete the orphaned headers (if there are any).
OnOff: phase Erase
dev_fd == 7
devctl returned 0
arrayinfo.unit_size 262144
calling devctl with erase struct:
status: 0
offset: 0x40000
limit: 0x40000
OnOff: Progress 000
devctl(7,-2146694912,xx,12,0) returned 0OnOff: Progress 100
FPGA info header @SWDL V1@
FPGA info version 1
FPGA info variant 9302
FPGA info HW index MU 41
FPGA info region <noRegion>
FPGA info step 0
FPGA info HW index IT 0
FPGA info ignore region/variant 1
FPGA info loop 0
FPGA info repeat 0
FPGA info CRC 3ace6582
SWDL: Stopping EFS driver!
slay: Unable to find process 'checkPersistence'
result of running command stop_efs_driver.sh is 0
SWDL: Starting EFS driver (automount)!
(devf t1::f3s_recover_boot:141) fs0p1 boot P[DC] U: 90
result of running command start_efs_driver.sh is 0
/HBpersistence/SWDL not found!
(devf t1::f3s_recover_boot:141) fs0p2 boot P[16C] U: 50
(devf t1::f3s_recover_boot:141) fs0p3 boot P[1DA] U: 38
(devf t1::f3s_recover_write:965) fs0p3 bad H[2E] P[1C0] # 000000 # FFFFFF1F
(devf t1::f3s_recover_write:965) fs0p3 bad H[274] P[1C0] # 00FFFF # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[274] P[1C0] # 00FFFF # 00000006
(devf t1::f3s_recover_write:965) fs0p3 bad H[275] P[1C0] # 000000 # 04000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[275] P[1C0] # 000000 # 04000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[276] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[277] P[1C0] # 000000 # 45042126
(devf t1::f3s_recover_write:1074) fs0p3 bad H[278] P[1C0] # 002602 # 68134506
(devf t1::f3s_recover_write:1074) fs0p3 bad H[279] P[1C0] # 000417 # 0101220A
(devf t1::f3s_recover_write:965) fs0p3 bad H[27A] P[1C0] # 000445 # 00000C06
(devf t1::f3s_recover_write:1074) fs0p3 bad H[27A] P[1C0] # 000445 # 00000C06
(devf t1::f3s_recover_write:965) fs0p3 bad H[27B] P[1C0] # 000022 # 00000004
(devf t1::f3s_recover_write:1074) fs0p3 bad H[27B] P[1C0] # 000022 # 00000004
(devf t1::f3s_recover_write:965) fs0p3 bad H[27C] P[1C0] # 00000C # 00000002
(devf t1::f3s_recover_write:1074) fs0p3 bad H[27C] P[1C0] # 00000C # 00000002
(devf t1::f3s_recover_write:1074) fs0p3 bad H[27D] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[27E] P[1C0] # 000000 # 79010004
(devf t1::f3s_recover_write:1074) fs0p3 bad H[27F] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[281] P[1C0] # 000000 # 00220F47
(devf t1::f3s_recover_write:965) fs0p3 bad H[282] P[1C0] # 004504 # 000C0026
(devf t1::f3s_recover_write:1074) fs0p3 bad H[282] P[1C0] # 004504 # 000C0026
(devf t1::f3s_recover_write:965) fs0p3 bad H[283] P[1C0] # 002211 # 0000000E
(devf t1::f3s_recover_write:1074) fs0p3 bad H[283] P[1C0] # 002211 # 0000000E
(devf t1::f3s_recover_write:965) fs0p3 bad H[284] P[1C0] # 000101 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[284] P[1C0] # 000101 # 00000006
(devf t1::f3s_recover_write:965) fs0p3 bad H[285] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[285] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:965) fs0p3 bad H[286] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[286] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[287] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[288] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[289] P[1C0] # 000D00 # 67134506
(devf t1::f3s_recover_write:965) fs0p3 bad H[28B] P[1C0] # 001345 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[28B] P[1C0] # 001345 # 00000006
(devf t1::f3s_recover_write:965) fs0p3 bad H[28C] P[1C0] # 000062 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[28C] P[1C0] # 000062 # 00000006
(devf t1::f3s_recover_write:965) fs0p3 bad H[28D] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[28D] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[28E] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[28F] P[1C0] # 000000 # 07000F04
(devf t1::f3s_recover_write:1074) fs0p3 bad H[290] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[291] P[1C0] # 000000 # 0A450466
(devf t1::f3s_recover_write:1074) fs0p3 bad H[292] P[1C0] # 000000 # 01220747
(devf t1::f3s_recover_write:1074) fs0p3 bad H[293] P[1C0] # 004504 # 00010146
(devf t1::f3s_recover_write:965) fs0p3 bad H[294] P[1C0] # 006113 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[294] P[1C0] # 006113 # 00000006
(devf t1::f3s_recover_write:965) fs0p3 bad H[295] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:1074) fs0p3 bad H[295] P[1C0] # 000000 # 00000006
(devf t1::f3s_recover_write:965) fs0p3 bad H[296] P[1C0] # 000000 # 00000002
(devf t1::f3s_recover_write:1074) fs0p3 bad H[296] P[1C0] # 000000 # 00000002
(devf t1::f3s_recover_write:1074) fs0p3 bad H[297] P[1C0] # 000000 # 00000006
и так строчит до последнего.
Проблема в прошивке efs persist или в железе?
И как это побороть?
Последний раз редактировалось vsnic; 20.03.2017 в 21:26.
Пните в нужном направлении, пожалуйста!!!
вставьте флешку с прошивкой ДЛЯ ЭТОЙ МОДЕЛИ в слот 1, включите и отойдите на 10 минут.
ВОТ что.JPGДоброго времени суток ! Есть MMI 3G+ c Q7 после перезагрузки перестала работать клава. Помогите поднять пожалуйста . Дело в том что не как не могу разобратся с терминалом выдает не то что хочется видеть ) вот что отвечает когда просто подключено
Может есть кто по удаленке поможет за вознаграждение ?
Привет ! Да как я только скорость не ставил (( Сегодня купил еще USB -COM буду пробовать . Вопрос еще в самой железяке я так понял без разницы какая скорость и тд , все что установил в ПУТТИ это главное ?
Hello
I have my MMI 3G who don't start up so I have connect TTL (zerbino) but I don't know all the command....
Is it possible to pass command into Putty to the MMI 3G for to force the MMI to boot on the SD Card ?
Best regard
вот
А килилица и другие настройки может не так у меня ?
translator to help ))))
it was not addressed to you
Все победил отоброжение )) Пипец куча шнурков и все хлам ! Взял обычный kline в нем припаял и все хорошо ,))
hello
I have connected now TTL on the MMI 3G and I have the message here :
NO FPGA loaded!
