DELPHI MIB2 STD - not powered
Показано с 1 по 2 из 2
    г. Львов
    По умолчанию DELPHI MIB2 STD - not powered
    Good day.
    Carradio DEPLHI MIB2 STD is not powered.
    Here is log of terminal:
    Код:
    J6ECO_HW02_BOARDHKP: 00:00:00:000:000-[0]0:1; ecu_mgr.c:289; NOTIFY - HKP started
    WakeupReason:1
    RESF:0
    Batt volt @sampling = 12759
    Batt volt @sampling = 12739
    Batt volt @sampling = 12819
    Batt volt @sampling = 12860
    [19]:VBAT 12860 mV, PGood_OK: 1
    [22]:Main Pwr Enabled
    [24]:3v3_5v_PGood_OK: 0
    [26]:3v3_5v_PGood_OK: 0
    [28]:3v3_5v_PGood_OK: 0
    [30]:3v3_5v_PGood_OK: 1
    [32]:1.8V Enabled
    [33]:J6EO_PMIC PWR
    [34]:PMIC_SEQ_OK: 0
    [36]:PMIC_SEQ_OK: 0
    [38]:PMIC_SEQ_OK: 0
    [40]:PMIC_SEQ_OK: 0
    [42]:PMIC_SEQ_OK: 1
    SMPS1_CTRL:0x11
    SMPS1_VOLT:0x42
    SMPS2_CTRL:0x11
    SMPS2_VOLT:0x3e
    SMPS3_CTRL:0x11
    SMPS3_VOLT:0x3e
    SMPS4_CTRL:0x11
    SMPS4_VOLT:0xae
    SMPS5_CTRL:0x15
    SMPS5_VOLT:0x6a
    LDO1_CTRL:0x51
    LDO3_CTRL:0x11
    LDO3_VOLT:0x13
    LDO4_CTRL:0x11
    LDO4_VOLT:0x31
    LDO5_CTRL:0x11
    LDO5_VOLT:0x13
    SW_REVISION:0x23
    PMIC REGS OK
    [68]:HK_PMIC_PWR_EN
    [69]:Temp 29, Temp_OK: 1
    [74]:Flash_Rst_Released
    [76]:AP_Rst_Released
    -K0R    Build Date:20170505 ID:21543 UBN:0556
    -OPT    0xFE, 0xDF, 0xFF, 0x85
    -RESF   0x00
    Info: Unused_Int        = 0x00 times
    Info: Real_Wdt_Int      = 0x00 times
    Info: OS Reset          = 0x00 times
    HKP: 00:00:00:090:000-[90]0:1; persistent_storage.c:1828; WARN - EA PS not avail for blk  255!
    HKP: 00:00:00:560:000-[560]0:1; eeprom_drv.c:288; WARN - STARTUP=x01, x00
    PS Init Completed @596
    PS wait for handshake
    HKP: 00:00:00:601:000-[601]0:1; voltage_mon.c:1018; WARN - NV:13307mv
    HKP: 00:00:02:003:000-[2003]0:1; persistent_storage.c:1652; WARN - chVer=0, 0
    Active Blk Addr: 000eb800
    ECNT of act blk: 0000656f
    Sector: 5
    Active Blk Addr: 000ec000
    Sector: 6
    Max ECNT: 0000656f
    Min ECNT: 0000656f
    HKP: 00:00:07:087:000-[7087]0:1; watchdog_mgr.c:1003; WARN - Wd_Manager : 1st_WARNING, -Wd_VIP_Supervisor- NOT reporting the Alive Msg for 3 sec
    HKP: 00:00:07:094:000-[7094]0:1; watchdog_mgr.c:1003; WARN - Wd_Manager : 1st_WARNING, -Wd_AP_Supervisor- NOT reporting the Alive Msg for 3 sec
    HKP: 00:00:10:087:000-[10087]0:1; watchdog_mgr.c:1028; WARN - Wd_Manager : 2nd_WARNING, -Wd_VIP_Supervisor- NOT reporting the Alive Msg for 6 sec
    HKP: 00:00:10:095:000-[10095]0:1; watchdog_mgr.c:1028; WARN - Wd_Manager : 2nd_WARNING, -Wd_AP_Supervisor- NOT reporting the Alive Msg for 6 sec
    HKP: 00:00:14:087:000-[14087]0:1; watchdog_mgr.c:1056; FAULT - Wd_Manager : TIMEOUT 10sec is REACHED, -Wd_VIP_Supervisor- is DEAD!-->Request RESET of System
    HKP: 00:00:14:095:000-[14095]0:1; watchdog_mgr.c:1216; WARN - Wd_Manager : Emergency RST Notification is send out
    HKP: 00:00:14:102:000-[14102]0:1; watchdog_mgr.c:1056; FAULT - Wd_Manager : TIMEOUT 10sec is REACHED, -Wd_AP_Supervisor- is DEAD!-->Request RESET of System
    HKP: 00:00:19:087:000-[19087]0:1; power_mgr.c:1546; INFO_LO - Coldstart frm VIP
    [19093]:Flash and AP Resets
    [19095]:Amp Standby Disable--
                                  HKP after INIT
    EMMC inside is HBBR1 - 4Gb
    I saved an existing EMMC dump.
    Please help to determine the malfunction by the terminal log.
    If there is a dump of EMMC 4Gb then please share.
    Thanks!
    Последний раз редактировалось Jagupop; 24.11.2021 в 13:54. Причина: ошибочку исправил
    Hi
    Can you send me dump of EMMC ? Please
    navserwis@op.pl
