в паре с ним неплохо показал себя
http://www.tp-linkru.com/products/de...odel=TL-MR3040
может и модемы свистки цеплять, и по вифи раздовать и брать и раздовать по вифи одновременно
Hi Sergey,
can you explain a little better?
Traslating with google I can't understand if you are advicing us to buy it.
Can we use it with dub e-100?
Using it, is it possibile to connect a unit 666 to internet?
Thanks
for Italy simple buy from EBAY
MMI working onli with chipset based
AX88772
AX88772A
AX88172
Can I use it to connect an unit 666 to online services?
Should I connect to MMI using wireless or dlink e-100 (AMI to usb)?
mmi 3gp unit?
yes
ami -> usb -> dub-e100 ->tl-mr3040
mr3040 incoming internet with 3g/4g modems or wifi from another ap
outcoming with DHCP to Ethernet( to dub e100 ) and wifi AP (to you devices)
Hi Sergey,
what I have to set in hidden menù of MMI 3g+ to be able to use google maps with the configuration you wrote above?
Thanks
Hello Sergey, I write from Italy ...
I have configured a raspberry with wi-fi router, and I'm trying to get it to connect properly with the 3G + WLAN 5F 666
probably the gateway address of the 5F should be the same as the router, and we can not change the.
is there any script to change the values directly to IP gateway?
thank you for your invaluable help to all forums.
