у кого есть покидайте от разных систем IFS может колекция драйверов пополницца
хотя там не SH4 а ARM (((
ВО КАК
DESCRIPTION=Realtek rtl-8150 USB ethernet dongle driver
DATE=2006/02/27-14:08:43-EST
STATE=stable
HOST=osbuild.ott.qnx.com
USER=osbuild
VERSION=6.3.0SP2-153
TAGID=703
%C Class Driver for Realtek rtl8150 Ethernet dongle.
Syntax:
io-net -drtl8150 [options*] &
Options:
did=0xXXXX USB device ID.
vid=0xXXXX USB vendor ID.
busnum=0xXX USB bus number.
devnum=0xXX USB device number.
duplex=0|1 Half (0) or full (1) duplex mode.
iftype=num Interface type. <net/if_types.h> (default IFT_ETHER)
lan=num LAN number.
mac=XXXXXXXXXXXX Interface address of the controller.
media=num Media type <hw/nicinfo.h> (default NIC_MEDIA_802_3)
mru=num Maximum receive unit (default: 1514)
mtu=num Maximum transmission unit (default 1514).
nomulticast Disable multicast support.
path="name" Set device name. Default "/dev/usbenet0"
phy=num Address of connected PHY device.
priority=N Priority of the driver event thread. (default 21).
promiscuous Enable promiscuous mode.
receive=num Set the number of rx descriptors (default 5).
speed=10|100 Media data rate in Megabits/Second
transmit=num Set the number of tx descriptors (default 10).
uptype=name Interface name. (default "en")
verbose=N Set verbosity level. (default 0)
wait=num Wait num seconds for USB stack (default 60 seconds).
у них есть мини имедж для Zmodema 1мегабайт самого необходимого и дальше флешит шьет просто все
