Hi theed,
I got one XILINX (usb cable platform) FPGA programmer, but on topjtag flash tool is no option to select this device.
Do you know any other tool which is support XILINX Platform Cable usb for connect MMI?
Regards
Hi theed,
Regards
An update on the jtag flashing, notice it is done by boundary scan.
This means all the pins on the sh7785 are driven the topjtag software.
Boundaryscan is usally used for debugging boards, and most new cpu offer this option.
So what is basically done is the both flashchips are controlled by the cpu in a 'debug' mode.
The programmer I used is the TIAO multi -protocol adaptor with a ft2232, and the topjtag software.
I can confirm this works, my MMI is up and running.
I flashed the IPL, IFS-EMG, FPGA and the BIOS areas with success.
The only problem is that the MMI has somekind of auto shutdown within 5 min, so writing large files must be done in small portions.
Maybe other software with boundary scan will work,I only tested the TIAO and topjtag.
Do you have any link where i can order this TIAO with ft2232 or any other good tools?
Regards
Hello I used the http://www.diygadget.com/tiao-usb-mu...2c-serial.html this worked for me.
Hello, i am new here but i would have a question.
Does anybody know if I would be able to use Jtag for programming new (emty ) flashes on board ? So take the old of replace them with new empty one's ?
And, this special small IFS for sending thru Z-modem to keep the board alive while flashing .
Regards,
Roy
Have you creat any project files on topjtag programmer?
I can read the flash memory but there is something wrong, lot of bytes are FF.
sorry double post
Hello
I got a broken Main Unit from a friend.
The screen was black and they dont't started.
Than i tried to recover the Unit.
But i made a big mistake:mad:
In the IPL mode I wanted to erase the FPGA headers
I did not write
flashit -a 40000 -e 1000
but
flashit -a 4000 -e 1000
I probably need glasses
I have a zero less:sorrow:
After the reboot I have no communication between the Unit and the Putty Terminal.
But the unit reacts if i take the three buttons to reboot the unit.
Can someone give me a tip, how i can recover the Unit.
I think I have erase the IPL Image with the wrong command.
I have an IPL.bin file, but I don't know how can I flash it to the chip without the Terminal
If the IPL is dead, as in your case, you have only the way through a JTAG Flash of the memory area. But there is only a very small group of people, which is able to do...
Hello,
i need some assistance with recovering a MMI unit. I cant enter emergency mode so i can try and recover the MMI unit. I tried to recover it via zmodem but the timeout is a problem because of the transfer speed vs size of ifs-emg.img. I bought a JTAG http://www.seeedstudio.com/depot/FT2...ard-p-737.html and i need some assistance how to flash the file via JTAG or if someone has a smaller file so i can revive the unit.
I connect the JTAG. I press the "read" only reads the piece. The rest - "FF". How do I fix this?
кто может разжевать это - "and that a24 is connected to W11/cs0_n."?
что тогда в СЕ?
проблема в том - что 1 флешь определяется полностью и работать с ней можно (писать и стирать частично), а вторая определяется частично, в итоге записать ее можно, но стирать ее можно только полностью!! и время работы с ней увиличивается в 4-5 раз... (визуально)
п.с тема рабочая, хотя вопрос выше остался не решенным..
а так - прошил голову
еще вопрос оставшийся без ответа - как топикстартер прошил BIOS?
в моем случае не надо было, но для общего развития было интересно - область BIOS прочесть не получилось
You can not write the efs to the unit by the ipl, there is not enough time the unit will power off.
Only method is by jtag, i did it and the unit is fully working.
I flashed the bios when running in command mode in the emergency mode, the bios is the most high adress range.
Hi.
Thanks to information on this thread, I've owned a TIAO ft2232 JTAG, and TopJTAG Flash software to repair a dead MMI, I've sucesfully flashed flash 1, but when I change pin #WE from W12 to Y17 and try to reconnect, I get a message indicating that flash is not CFI compliant, and chip is not possible to erase chip sectors, it must be erased completely, so flash by steps is not possible. Does anybody had and solve this problem?
Best regards.
Hi finally I succeed to read and write the flash. I have a problem tough, one of the 2 flashes is damaged, the second flash who need we=y17 to write in, with data lines from d16 to d31. Can anyone point which one is that flash to change it. I don't want to change them both.
