Электрические схемы управления двигателями AAN и ABH,распиновка ЭБУ,коды
Выкладка по электрике на двигатели, устанавливаемые на audi s4/s6
AAN
http://karec.users.photofile.ru/phot.../168741916.jpg
Code description 15 Ignition switch supply
30 Battery supply
A10 Ignition amplifier module
A40 Engine management control unit (ECM)
A110 Trip computer
B11 TDC Sensor
B12 RPM Sensor
B20 Knock Sensor (KS)
B32 Mass Air Flow (MAF) sensor
B41 Air Temperature Sensor (ATS)
B50 Coolant Temperature Sensor (CTS)
B62 Barometric Pressure Sensor (BPS)
B71 Heated Oxygen Sensor (OS), zirconia
B91 Camshaft Sensor (Hall effect)
B101 Vehicle Speed Sensor (VSS)
E6 Spark plugs
E200 Air Conditioning (A/C)
F13 Fuel pump Fuse 15a
F27 ECM fuse 5a
F28 Injector fuse 15a
K35 Fuel Pump Relay
M30 Fuel Pump
P1 Tachometer
R30 Throttle Position Sensor (TPS)
S32 Idle Switch
T3 Distributorless ignition coil (single spark)
X1 Diagnostic Connector
Y30 Fuel injector (Multi-point)
Y41 Idle Speed Control Valve (ISCV), 2-wire
Y50 Purge Valve (CFSV)
Y96 Turbo Boost Control Valve (TBCV)
Предохранители, относящиеся к двигателю
http://karec.users.photofile.ru/phot.../168741906.jpg
расположение компонентов
http://karec.users.photofile.ru/phot.../168741911.jpg
Коды ошибок
Audi (Motronic M2.3) Fault codes
Flash FCR Description
2111 00513 Engine RPM sensor or RPM sensor circuit
2112 00514 Top Dead Centre (TDC) Sensor or TDC circuit
2113 00515 Hall Effect Sensor (HES) or HES circuit
2121 00516 idle switch contacts
2212 00518 Throttle Pot Sensor (TPS) fault or TPS circuit
2312 00522 Coolant Temperature Sensor (CTS) or CTS circuit
2322 00523 Air Temperature Sensor (ATS) or ATS circuit
2142 00524 Knock Sensor (KS) 1 or KS circuit
2342 00525 Oxygen Sensor (OS) or OS circuit
2223 00528 Barometric Pressure Sensor (BPS) or BPS circuit
2234 00532 supply voltage, greater than 16 V or less than 6 V
2231 00533 Idle control, adaption limit exceeded or not achieved
2341 00537 Oxygen Sensor (OS), control limit exceeded or not achieved
2144 00540 Knock sensor (KS) 2 or KS circuit
2214 00543 Max. engine speed exceeded
2224 00544 Turbo, maximum boost pressure exceeded
2324 00553 Mass Air Flow Sensor (AFS)
00561 mixture control, adaption limit exceeded or not achieved
00575 inlet manifold pressure
2141 00577 Knock control cylinder 1
2141 00578 Knock control cylinder 2
2141 00579 Knock control cylinder 3
2141 00580 Knock control cylinder 4
2141 00581 Knock control cylinder 5
4343 01247 Carbon Filter Solenoid Valve (CFSV) or CFSV circuit
4411 01249 Injector No. 1 or injector circuit
4412 01250 Injector No. 2 or injector circuit
4413 01251 Injector No. 3 or injector circuit
4414 01252 Injector No. 4 or injector circuit
4421 01253 Injector No. 5 or injector circuit
4431 01257 Idle Speed Control Valve (ISCV) or ISCV circuit
4442 01262 Turbo Boost Control Valve (TBCV) or TBCV circuit
65535 ECM fault
4444 No faults found in the ECM. Proceed with normal diagnostic methods
Распиновка ЭБУ:
http://karec.users.photofile.ru/phot.../168741909.jpg
http://karec.users.photofile.ru/phot.../168742270.jpg
http://karec.users.photofile.ru/phot.../168742273.jpg
