как увеличить время работы rns для передачи через zmodem?
mini ifs image где взять под rns850 mu9478
в BOLOMODE не будет watchdog.
Hi,
guys i write in english because my russian language are not the best.
Long time ago have learn russian to the school,but because not speaking it goes away.
Anyway have try to update my mmi 3gp to the k942 and something goes wrong.
Now mmi it start direct into emergency update and when sd card inserted gives metainfo crc error.
Have removed the unit and make uart connection,so please help me to resuscitate my unit.
Because my qnx abilities are not to good.
Please take a look to the teraterm log.
Вложение 59866
Best regards.
In the end succed with another fw version.
Already try from 3 sources.
The one that it worked,is from my friend.
Hello,
Can anyone assist please with RNS850? Update failed and unit is now in boot loop.
After first reboot, language is changed from English to German on display and fan
kicks in full speed and lights are on all the time on main unit.
I have Segger J-link not sure if I can flash main unit since all I read is about TIAO flasher.
Update that failed is FW K0821. No problem with soldering anything if needed.
I'm willing to pay for support, no problem. Thx guys
Fan spinning fast -> IOC in bolo mode.
Hi grozni,
I told you about the V850 bolo mode and the way to fix by update.txt at the other board forum ...
But congo is also a crack to rescue mmi units ;-)
Hi, i have updated my Q5 3G+ from 900 to 8R0906961FC_К0942_A4_A5_Q5_Q7 and it is stuck on constant rebooting. 1) mmi logo appears 2) menu appears for about 25 seconds 3) MMI shuts down and repeats all over again.
Have tried to run "emergency update" script from this threat but no success. System shuts down before running the script.
Any ideas how to fix that?
Thank you!
Read the whole threat.
You need to go in IPL mode and boot emergency from there.
This way you can fix it and might not need to for full chip reflash.
Прошу помощи у знающих.
По собственной глупости почти (надеюсь что почти) увалил MMI 3G High. (A4 японец)
Что сделано... 1) поправил в EEPROM список языков (как у европейцев). 2) отключил в зеленке проверку региона и обновился в автоматическом режиме на K0257_6_D1 (8R0906961DQ). После обновления она запустилась, но на японском. 3) опять же из зеленки удалил раздел с картами. После перезапуска она уже запустилась без текста (выбор языков не менял ничего) 4) Черт меня дернул и загнал ее из зеленки в EmmApp.
Сейчас имею такую картину. MMI требует прошивку, но вот версия MU9309, а обновления такого у меня нет(
Если я правильно понимаю мне нужно K_0275 (8R0906961BP), но нигде не могу его найти, готов купить... и вернуть как было в EEPROM...
Или уже не поможет? (смущают упоминания о том что восстанавливать надо с той же версии что и была перед смертью)
Или все таки можно ее довести по европейца?
к UART пока не цеплялся, но если нужно не проблема.
MMI3G Basic,
HSA148 8R1035652A Bios Dump / IPL dump from sw 260
any body can help ?
regards,
Люди добрые, прошу вашей помощи советом!!
Имеется MMI 3g high. При перезагрузке нажатием трех кнопок переходит сразу в ipl режим.
Вложение 61183
я так понимаю что эти адреса пустые
0x00040000 fpga 746472 из 786432 (768 кб)
0x00100000 fpga em 746472 из 786432 (768 кб)
при попытке записать с sd карты вот что выдает
Вложение 61191Вложение 61192Вложение 61193
Как записать эти сектора? почему он не видит эти файлы
Sd карты с прошивкой 257_5_d1
привет,
мозет кто посоветоет если мозно ли подниат етот циц от бмщ приложу лог и кокии команди делал, и сто полуцил, истотии незнаю. принисли уже такоии. перезагруска каздее 15 секунд. на свезе нету по цан. в какоиу стотону ити хот.
оцен блогадарен.Вложение 61580
Приветсвую всех
Есть Q7 3G High моя проблема такова, по глупости прошил eeprom 8R1035666_3GP
Получаеться тепер что в емердженси просит MU9498. Помогите люди добрые!
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]
CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_FPGA_9308_D1_09324A
(0ms)
*** Old-fashioned mark found on IFS @0x1c0000: .zero=0x3000001e
*** Old-fashioned mark found on IFS @0x780000: .zero=0x10000000
starting image @780000 ...
Startup: , built 2011/07/19_09-41-26_UTC
RAM : 128 MB @0x08000000
RAM : 128 MB @0x40000000
NVRAM: 31 MB @0x5e100000
RAM : 225 MB @0x50000000
FLASH: 128 MB @0x00000000
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v8804aae0
Welcome QNX6.3.2 (QNXLabel RL_qnx_os_632_PSP3_08041A)- Harman/Becker MMI3G Build 9307/08 D1-13234A
s: 0
v: 0
r: 0
m: 0
mkprocsymlinks 0.10, reading /mnt/ifs-root/etc/system/efs_symlinks.cfg
done
s: 0
v: 0
r: 0
m: 0
mkprocsymlinks 0.10, reading /mnt/ifs-root/etc/system/ifs-root_symlinks.cfg
done
starting server starter...
# multicored [000000000.757]:version 4.1.d, verbosity 1 (supported 4), scope 0x00000001, console: /dev/ser1 (fd=3), FILE_LOGGING, TESTCONTROL
multicored [000000000.789]:udp: broadcaster created
multicored [000000000.791]:attached to filesystem at /hbsystem/multicore, port 851
multicored [000000000.801]:MACHINE:SH(1), total MEM 504365056, 1: 271582976 SH7785 (SH4A) 792MHz, FPU
multicored [000000000.801]:sloop active
multicored [000000000.803]:lo0127.0.0.1255.0.0.0
NVLOADER: Booting DSP (DRAM Setup time = 1000 us)...
NVLOADER: Going to call nvTsrmRawLoad for file /etc/NvDspCodecs.elf
NVLOADER: Done
Enabling DMA using channel 7
Overriding default Interrupt Priority
Current debug level = 0x7fffffff
dmaChannel = 7, interrupt thread priority = 21
multicored [000000001.307]:listener on port 851 active, fd=7
devg-NVMEM: Mapped vaddr 0x38100000 to paddr 0x5c257000
dev-nvram: PL_qnx_dev-nvram_07225A, built 2007/06/01_15-44-08_UTC
dev-nvram: page_size:4096
dev-nvram: signalling register 10ee:9308:0:40:40 [vid:did:bar:offs:mask]
dev-nvram: CPU: SH7785 (5th cut or higher, clk_mode 20) [10300700:250, 133735fa]
dev-nvram: map '/dev/nvram/navi' to 0x5e100000-0x5fffefff
dev-nvram: map '/dev/nvram/.guard' to 0x5ffff000-0x5fffffff
dev-nvram: SelfRefresh was inactive
UART: Mod:0E Date:08511A Ver:2.2.1
devc-ser8250hb: UART supports FiFo counter
devc-ser8250hb: UART supports 32bit access
devc-ser8250hb: RX_FIFO_SIZE:512 TX_FIFO_SIZE:512
devc-ser8250hb: set IBUF size to 4096
devc-ser8250hb: RX_FIFO_SIZE:32 TX_FIFO_SIZE:32
Debug filehandle = 4
For further debug messages have a look at multicore output consoles '/hbsystem/multicore/navi/g'
Mask = c3
GPIO 7 set to = Low
[pcidma] finished.
JVMEXEL085W
WARNING: The command line argument "-jxe:" has been deprecated.
WARNING: Use "-jxe <path>" instead.
DSIVersion: 0.0.0
DSISource: DSI 2010_44_44
DSI-Build-Versionio-media-nvidia built: Mar 4 2009 16:48:41 against Official Tree
30.11.09/v1.138.3nv_global.verbose = 0
ReleaseLabel: Integration_AU_MMI3G_11320P
Path=0 - XILINX MMI3G_8
target=1 lun=0 Direct-Access(0) - TOSHIBA MK4036GA Rev: TA15
Virtual Address for CDDA DirectIO = 8394000
start JDSI bundle
jdsi.loglevel : 2
No External Component found
stream factory memory mode : classic
dsigen v1.138.3 - core v2.1
prop os.arch : sh4
prop jdsi.3SoftOSGi : true
DSI dispatcher disabled!
NEDL: Acquiring Capture Unit
NEDL: Acquiring Layer
NEDL: Switching source to 0 (Format = PAL)
NvRender: Reconfigure Video Port to PAL
Could not find library libxml2.so.1
msgpassing channel opened on /dev/dsi/data
DSIAddressbook (0) - v10.0G1.138.3
DSIAddressbook (1) - v10.0G1.138.3
DSIAddressbook (2) - v10.0G1.138.3
DSIAddressbook (3) - v10.0G1.138.3
DSIAMFMTuner (0) - v8.0G1.138.3
DSIAudioManagement (0) - v8.1G1.138.3
DSIBluetooth (0) - v4.3G1.138.3
DSIBrowser (0) - v4.0G1.138.3
DSIBrowser (1) - v4.0G1.138.3
DSIBrowser (2) - v4.0G1.138.3
DSICallLists (0) - v3.0G1.138.3
DSICarClimate (0) - v4.0G1.138.3
DSICarComfort (0) - v3.0G1.138.3
DSICarParkingSystem (0) - v2.4G1.138.3
DSICarSuspensionControl (0) - v2.0G1.138.3
DSICarLight (0) - v2.0G1.138.3
DSICarService (0) - v3.2G1.138.3
DSICarDriverAssistance (0) - v3.0G1.138.3
DSICarKombi (0) - v4.4G1.138.3
DSIDABTuner (0) - v5.3G1.138.3
DSIDiagHMIAttribs (0) - v4.0G1.138.3
DSIIconrenderer (0) - v1.0G1.138.3
DSIIconrenderer (1) - v1.0G1.138.3
DSIDataDisplay (0) - v5.0G1.138.3
DSIDisplayManagement (0) - v9.6G1.138.3
DSIInfotainmentRecorder (0) - v2.0G1.138.3
DSIKeyPanel (0) - v2.4G1.138.3
DSIMapViewer (0) - v18.3G1.138.3
DSIMedia (0) - v4.6G1.138.3
DSIMediaRecorder (0) - v1.4G1.138.3
DSIMOSTInfo (0) - v3.0G1.138.3
DSINavigation (0) - v72.0G1.138.3
DSIObexAuthentication (0) - v1.0G1.138.3
DSIPhonoConv (0) - v1.0G1.138.3
DSIPersistence (0) - v10.1G1.138.3
DSIPowerManagement (0) - v3.4G1.138.3
DSIStartup (0) - v1.2G1.138.3
DSIProfileManager (0) - v6.0G1.138.3
DSISDARSTuner (0) - v2.2G1.138.3
DSISMS (0) - v4.1G1.138.3
DSISound (0) - v8.0G1.138.3
DSISSS (0) - v6.2G1.138.3
DSISwdlDeviceInfo (0) - v1.1G1.138.3
DSISwdlLogging (0) - v1.1G1.138.3
DSISwdlProgress (0) - v1.2G1.138.3
DSISwdlSelection (0) - v2.7G1.138.3
DSITelephone (0) - v10.0G1.138.3
DSITIMTuner (0) - v2.3G1.138.3
DSITmc (0) - v9.2G1.138.3
DSITmcOnRoute (0) - v6.0G1.138.3
DSITTS (0) - v4.0G1.138.3
DSITTS (1) - v4.0G1.138.3
DSITunerAnnouncement (0) - v1.0G1.138.3
DSITVTuner (0) - v5.2G1.138.3
DSIVCardExchange (0) - v5.0G1.138.3
DSIWavePlayer (0) - v5.2G1.138.3
DSIWavePlayer (1) - v5.2G1.138.3
Duration of starting JDSIBundle : 5639ms
##### Error caught in event loop: java.lang.ExceptionInInitializerError; event loop continuing ...
java.lang.ExceptionInInitializerError: java.lang.NullPointerException
at de.audi.tghu.storage.DSIStorageProvider.getInt(Unk nown Source)
at de.audi.tghu.storage.StorageManagerImpl.getInt(Unk nown Source)
at de.audi.tghu.fwhmi.KbdHandlerDSI.<clinit>(Unknown Source)
at java.lang.J9VMInternals.initializeImpl(Native Method)
at java.lang.J9VMInternals.initialize(Unknown Source)
at de.audi.tghu.fwhmi.FwHMI.startLastMode(Unknown Source)
at de.audi.tghu.fwhmi.FwHMI.getInstance(Unknown Source)
at de.audi.atip.base.Framework.getHMIService(Unknown Source)
at de.audi.tghu.fwhmi.EventTrail.logEventDispatch(Unk nown Source)
at de.audi.tghu.fwhmi.EventQueue.dispatchEvent(Unknow n Source)
at de.audi.tghu.fwhmi.EventQueue.eventLoop(Unknown Source)
at de.audi.tghu.fwhmi.EventQueue$EventDispatchThread. run(Unknown Source)
multicored [000000040.983]:debuglevel changed to 1, connection /hbsystem/multicore
multicored [000000040.984]:startup phase ending for 0
/lsd/lsd.sh[35]: route: not found
